Aktuelle Zeit: 15. Juni 2015 13:43
Ein neues Thema erstellen Auf das Thema antworten  [ 22 Beiträge ]  Gehe zu Seite 1, 2  Nächste
BeitragVerfasst: 24. Januar 2008 20:13
Hi
Im starting to make some drawings about dimmaktor.
Any comments and ideias are very welcome.
Still studing the dimmer part. Since a have copy the idea from anoother project.. if you understand the mosfet part action, please explain it to me, since i cant simulate it with acurrency.
Keep it cool
Goahead
Dimmer_Project.zip [124.82 KiB]
114-mal heruntergeladen
BeitragVerfasst: 24. Januar 2008 23:48
Hi Goahead,
where do you have that schematic from?
Is it really implemented like it is in the DIMMER_SCH.jpg?
Or is it the information you got from the Jung Dimmaktor?
Thanks for further information!
Best regards
Markus
BeitragVerfasst: 25. Januar 2008 17:13
Hi Markus
It has nothing to do with Jung dimmaktor
I got the ideia from a friend...implemented and working. but with other mosfets.
You can get lots of dimmer schematics, and they all look the same (one or two mosfets used)
The schematic is similar to the original, but it uses diferent mosfets, optocoplers etc ect.
Owner of the original ideia explain to me the zero detection part, but im still waiting for the mosfet circuit explanation. Its not hard to understand mosfets or triacs, but i dont understand the use of 2 mosfets per dimmer.
Since mosfets are diferent from original, i have to check if circuit surrounding Gate is OK.
Circuit has no protection implemented yet from the output zone.
They will be no Processor Block, since all pins should arrive from PCB below that contains AVR.
Zero detection will be send to lower PCB and controles_Z will arrive also from there.
Please check and suggest improvements to circuits.
Best regards
Goahead
BeitragVerfasst: 25. Januar 2008 20:54
Hi Goahead,
do you know the name of the original fet´s?
Best regards
Markus
BeitragVerfasst: 25. Januar 2008 21:25
Its an old Fairchild IRF830
"Drain to Source On Resistance" is a bit high.
Thats why it was changed.
Goahead
BeitragVerfasst: 22. Februar 2008 12:56
Hallo Dimmermaker ;-)
Hier Lesestoff für Universaldimmer:
http://publikationen.dpma.de/DPMApublik ... entStart=1
im Dokument dann recht oben auf "Volldokument" klicken
BeitragVerfasst: 22. Februar 2008 16:47
Oldcoolman: Da bist Du tatsächslich fündig geworden - respekt.
Leider findet man nur eine verbale Erklärung aber keine Schaltungsbeispiele. Da müßte wohl jemand die Funktionsbeschreibung in eine Schaltung umsetzten.
Sascha
BeitragVerfasst: 22. Februar 2008 20:23
Hi Oldcoolman,
gute Idee, die Patentrecherche.
Das ist mit ein Grund, warum sich mittlerweile manche große Firmen scheuen, Patente zu beantragen ;-)
Kannst Du die Patentnr. posten? Deine Session-ID ist abgelaufen, somit funktioniert der Link nicht mehr
Markus
BeitragVerfasst: 22. Februar 2008 21:32
Hallo nochmal.
Geht auf die HP vom DPMA und recherche...Einsteigerrecherche. da hab ich einfach "Universaldimmer" eingegeben. natürlich ohne die Gänsefüßchen ;-)
Dann sind da glaub 4 Patente gelistet.
Ganz wichtig war ja erst mal zu wissen, wie vorgegangen werden kann.
Ich hab 2 möglichkeiten rausgelesen.
Einmal wird zero spannung und zerostrom detektiert und danach gedimmt.
bei der andreren Schaltung wird Phasenabschnitt probiert und dann die
negative inuktiv bedingte Spannungspeaks gemessen (50V).
Ein kompletter Schaltplan gibts natürlich nicht, aber ich denk wir sind selber kreativ genug ;-)
BeitragVerfasst: 23. Februar 2008 12:04
durch den timeout hab ich 2 romane für die Katz getippt. könnt mich ja im chat fragen *fg*
Andreas Bild
BeitragVerfasst: 24. Februar 2008 12:46
Mal ein Vorschlag zu dem Universaldimmer. technologie= bridge
zero U + zero I
ist nur theorie. die Erkennung funzt nur nach der Positiven Halbwelle. Ich denke das reicht, da die Nullspannungserkennung auch nur nach der positiven Halbwelle erfolgt.
wäre schön, wenn das jemand mal ausprobieren könnte.
hab die Schaltung ins SVN
BeitragVerfasst: 24. Februar 2008 14:36
Hallo nochmal und zum diskutieren die Version für 2 FETs
BeitragVerfasst: 24. Februar 2008 20:01
Hi Oldcoolman,
da würde ich dann sagen schneller schreiben ;-)
Oder den Text vor dem senden einfach makieren und kopieren. Das Timeout ist schon recht hoch.
Der Einsatz schaut nicht übel aus. Aber preislich haben wir ja schon drübert diskutiert. Vielleicht findest noch eine Alternative oder kannst Leergehäuse abstauben :-).
david
BeitragVerfasst: 25. Februar 2008 09:54
Hallo, hab mal schnell ein Testbord zum selberätzen erstellt.
BeitragVerfasst: 26. Februar 2008 19:41
Ich hatte in einem anderen Thread schon auf den PC_Dimmer von Christian Nöding hingewiesen. Das Dimmen übernimmt der µC und wird über ein serielles Protokoll oder per DMX angesteuert. Christian ist sehr hilfsbereit und hat alles unter der GPL veröffentlicht. Da durch könnte das Projekt eine gute Basis sein um eine EIB-Ansteuerung zu implementieren.
Das Projekt ist auf dieser Seite zu finden:
http://home.arcor.de/christian.noeding/www.pcdimmer.de/index_sub.html oder
http://home.arcor.de/lt.sue/www.pcdimmer.de/index_sub.html
Hier der Schaltplan (seriell) von Christians Homepage:
http://home.arcor.de/lt.sue/www.pcdimmer.de/schaltplan/pc_dimmer_schaltplan_rev27_bta16-600b.jpg
Die serielle Schaltung habe ich mit 8 Kanälen schon aufgebaut und funktioniert sehr gut :-) Eine EIB-Version wäre super...
