Aktuelle Zeit: 15. Juni 2015 15:14
 Betreff des Beitrags: ETS
BeitragVerfasst: 3. Dezember 2012 09:47
Hello,
I'd like to know if your system, you must use the ETS program or if you have also developed your own setup?
cordially
 Betreff des Beitrags: Re: ETS
BeitragVerfasst: 3. Dezember 2012 10:56
you would use ETS to configure the components like you would do with every other KNX device.
You'll need a flashing-device, though. With it you need to flash the basic "operating system" to the freebus devices.
BeitragVerfasst: 3. Dezember 2012 18:11
Thank you René for your answer.
My questions is may be basic for you, but I try to understand, KNX system, your system freebus and also the German (thank you google translate :oops: ) !!!
I think, I understood to use the ETS program is requires a database with components freebus. Can you give me the link to download it?
Regards
BeitragVerfasst: 3. Dezember 2012 22:15
Any components using database from original moduls, other use freebus database.
in8,out8,out4,2in2out,Rollo (shutters),Dimming,inwall switch, inwall switch interfacemodul
and more use original database.
logic,ERT30(room temp control),smoke detector,kombisensor(temp,brightness),DCF...
use self made database
BeitragVerfasst: 4. Dezember 2012 08:36
thank you for your answer
BeitragVerfasst: 4. Dezember 2012 10:14
bipbip59 hat geschrieben:
You've to login to the website. Every module has a download link on the page (if you are logged in!)
BeitragVerfasst: 11. Juli 2013 11:53
What interface is used to connect the computer ETS software to the EIB bus?
Do you need to buy a module or can the rs232 module be used?
Thanks,
